FCP to Compressor question
adam taylor
on Sep 6, 2010 at 9:33:21 am
After sticking with the Export Queue for years, I finally decided to try the various ways of sending to Compressor.
My only gripe with Export Queue was having no way to save favourite settings, and having to re-enter the same data every time i open it up. So time to try the options in Compressor...
The one thing i cant seem to figure out though, is there a way to send to Compressor only the video between the in/out points on a timeline? Use In/Out Points is a great option in the Export Queue, but it seems to be lacking in the methods for sending to Compressor.
If its possible - can someone explain how?
thanks
Adam
Adam Taylor
Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
Character Options Ltd
Oldham, UK
http://www.sculptedbliss.co.uk
Rob Grauert
Re: FCP to Compressor question
on Sep 6, 2010 at 11:51:20 am
"My only gripe with Export Queue was having no way to save favourite settings, and having to re-enter the same data every time i open it up. So time to try the options in Compressor..."
I dunno what an Export Queue is, but to create you own custom setting, choose a setting in the Settings tab. Near the top of that pane, there are 3 buttons (if you're in FCS2, I dunno about the new FCS). The third button duplicates the selected setting. From there you can modify/name it in the Inspector tab. Then click the save button at the button of the Inspector
"The one thing i cant seem to figure out though, is there a way to send to Compressor only the video between the in/out points on a timeline?"
I'm not sure what you're doing because I've always been able to mark In and Out points in my timeline and send whatever I want to Compressor. You can also mark In and Out points in the Preview window in Compressor. Or, mark your In and Out of your timeline, export a reference movie, then bring the reference movie into Compressor.
Rob Grauert, Jr.
http://www.robgrauert.com
command-r.tumblr.com
adam taylor
on Sep 6, 2010 at 12:06:59 pm
Export Queue is fcp's built in batch exporter.
I have everything setup as i need in Compressor - thats not the problem...i need to send different sections of the timeline to different folders, at different settings. I found that compressor ended up with the same in/out points regardless of how i had set them prior to sending from FCP.
I'll try again - maybe my fault!
Adam Taylor
Oldham, UK
adam taylor
on Sep 6, 2010 at 1:18:54 pm
following on from your reply Rob, i've done some more tests and know what i did wrong.
if anyones interested, sending to Compressor from fcp will use the in/out points...however, once in Compressor i made the mistake of dragging the various clips into one batch window, applying the different settings to the various clips and submitting. Thats causes Compressor to lose the in/out point info and instead it renders the entire clip instead of the bit you set with I/O points.
So as long as you don't move a clip from its own batch window, it should export correctly when you apply your settings.
adam
Adam Taylor
Oldham, UK
Rob Grauert
on Sep 6, 2010 at 1:23:05 pm
Look at that, learnin something new everyday :)
Rob Grauert, Jr.
