shortcut for selecting transition
jason jones
on Sep 3, 2010 at 5:54:36 pm
"command t" add transition
then what if i want to delete or adjust that transition?
do i really have to click on the transition with the mouse?
i must be missing something super obvious right?
Dino Vince
Re: shortcut for selecting transition
on Sep 3, 2010 at 6:50:29 pm
if you do it right after you add the transition, Command Z will clear it. Other than that, yes I believe you have to click to select it.
