Apply Fade To All
Mick Haensler
Apply Fade To All
on Sep 2, 2010 at 5:09:35 pm
Years ago I used to work on Speededit quite a bit and it had a nifty little shortcut that would allow you to put a crossfade between every clip on the timeline with one keystroke. Is there a way to do this in FCP??
Mick Haensler
Higher Ground Media
Martyn Greswolde
Re: Apply Fade To All
on Sep 2, 2010 at 5:47:54 pm
As long as you want to apply your default transition (normally set to cross fade) make sure your play line is right at the beginning of your sequence, select all and drag up to the timeline viewer and drop on overwrite with transition.
Greswolde Photography
http://www.greswolde.com
I know little but I learn quickly!
Sterling Scott
on Sep 2, 2010 at 6:07:29 pm
Just Select all clips and cmd T. Or map a single keyboard key for the add transition function.
Mick Haensler
on Sep 2, 2010 at 6:24:32 pm
Thanks guys. Knew there had to be an easy way. Much appreciated.
Mick Haensler
Higher Ground Media
