Why does opening the audio part of a video file lead to over a minute of beach balling?
Darryl Thomson
on Sep 2, 2010 at 1:25:28 pm
Hello.
We've got very powerful macs, but every time we open the audio portion of a video or the audio waveform needs to display, we get a minute of beach balling. This delay increases.
It seems under a new log in it is less.
What is causing it? How can this be remedied?
Audio is so much smaller than video why should it freeze the system when it can cope with Gb size video files ok?
Any help would be much appreciated,
Dazzer
FCP 6.0.5
John Fishback
Re: Why does opening the audio part of a video file lead to over a minute of beach balling?
on Sep 2, 2010 at 1:55:53 pm
What video codec are you using and what are the audio parameters of the file - Sample Rate (Aud Rate) and Bit Depth (Aud Format)?
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
Darryl Thomson
on Sep 2, 2010 at 2:34:06 pm
It happens on DV PAL, HDV 1080i and Sony XDCAM 720p25 - so standard audio formats.
Dazzer
FCP 6.0.5
Rafael Amador
on Sep 2, 2010 at 4:54:19 pm
Try deleting the "Waveform Cache Files".
rafael
http://www.nagavideo.com
