Compressor Error -1
Ron Cole
Compressor Error -1
on Sep 1, 2010 at 4:17:11 pm
I have encoded seven sequences with the Blu-ray Encoding H264 however I have one that continues to fail. Compressor gives me an Error -1 what ever that means.
I have tried sending it directly from FCP and exporting a reference movie but have the same result.
I have also closed all of the applications and restarted the system - still the same result.
Does anyone know what this error means and how to make the sequence encode correctly?
Thanks, Ron
Ron Cole
Re: Compressor Error -1
on Sep 1, 2010 at 5:34:05 pm
What I did to finally fix it was to change the settings completely on export. The original file was Pro Res Proxy at 1920 x 1080 30fps. I tried to compress it as a reference file then a self contained file with the current settings and then re-compress all frames, self contained with current settings - the Compressor failed everything with the Error -1.
Then I changed the settings to Pro Res HQ 1920 x 1080 30P 29.97fps, re-compress all frames, make a self contained movie. Now with these parameters Compressor is working perfectly.
Seems like there could be a bug in the Pro Res frame rate within Compressor... anyway its working.
