from AE to FCP
Trace Burroughs
from AE to FCP
on Sep 1, 2010 at 1:52:20 pm
I know you can import an After Effects Project into Premier Pro using Dynamic Link or without, if I then save the Premier Pro project as an xml file can I then import it into Final Cut Pro, making it a FCP project.? Thanks
Trace Burroughs
LME COLLECTIONS
lme-collections.com
Dave LaRonde
Re: from AE to FCP
on Sep 1, 2010 at 2:43:26 pm
There's one way to know for sure -- try it.
Dave LaRonde
Sr. Promotion Producer
John Fishback
Re: from AE to FCP
on Sep 1, 2010 at 7:41:38 pm
Let us know if it works.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
Dennis Radeke
Re: from AE to FCP
on Sep 2, 2010 at 12:15:34 pm
No, that will not work. FCP does not understand what a .aep file is. You could render the After Effects comp, replace it's usage in Premiere Pro and then export to FCP. That would be the only way I could think of it working.
