XDCAM in FCP6
Laurie Gibbs
XDCAM in FCP6
on Sep 1, 2010 at 1:14:33 pm
Hello,
I am planning on shooting on a PMW-EX3 and editing in FCP 6.
Has anyone had any experience editing XDCAM EX in FCP 6? Does the native codec work with this version of FCP or will I have to transcode the footage before I can begin editing?
Thanks in advance,
Laurie
Sachin Desai
Re: XDCAM in FCP6
on Sep 1, 2010 at 3:37:02 pm
I've edited xdcam ex but of jvc 700. But if you can upgrade fcp to 7 it works fine.
Sachin Desai
Laurie Gibbs
Re: XDCAM in FCP6
on Sep 1, 2010 at 3:40:55 pm
Thanks Sachin,
Unfortunately, I haven't got the budget to upgrade at the moment. Thanks for the response though.
Laurie
Shane Ross
Re: XDCAM in FCP6
on Sep 1, 2010 at 5:57:50 pm
Just make sure that you are fully updated to 6.0.6...then you should be fine.
Shane
Sachin Desai
Re: XDCAM in FCP6
on Sep 3, 2010 at 2:10:35 pm
you can still edit it in fcp 6 only thing you want be able to do is take your timeline to color...
it will edit smooth in fcp 6 also
all the best
Sachin Desai
Laurie Gibbs
Re: XDCAM in FCP6
on Sep 3, 2010 at 3:48:55 pm
Thanks V much Sachin.
Rafael Amador
Re: XDCAM in FCP6
on Sep 3, 2010 at 5:23:15 pm
EX footage is supported since FC 6.0.2.
[Sachin Desai] "you can still edit it in fcp 6 only thing you want be able to do is take your timeline to color..."
No really. You can send your Time-line to Color.
What you can't do is to import the files directly from your media HD.
With FC 7 is possible ingest the files directly without sending from FC.
Cheers,
rafael
http://www.nagavideo.com
Sachin Desai
Re: XDCAM in FCP6
on Sep 4, 2010 at 4:27:48 pm
I was not able to, when i sen my time line in older color version (1) it only displayed red cross...
see whats new in color 1.5
anyways thats not the issue here...
editing xdcam in fcp 6.xx is smooth ...
Sachin Desai
