Boosting audio beyond 12dB
Charles House
on Aug 31, 2010 at 11:03:22 pm
I have a considerable amount of dialogue that, even when boosted the 12dB, isn't loud enough to be used. The hiss becomes a bit heavy, as well, so I'd prefer not to max out the gain too much, but I need the vocals to be listenable and audible. How can I boost the dialogue past that point without too much noise?
Michael Sacci
Re: Boosting audio beyond 12dB
on Sep 1, 2010 at 1:38:32 am
You would have to reduce the noise before you raise the levels. Best to do this in SoundTrack Pro. STP has a good noise remover for things like hisses if the sound is constant.
Rich Rubasch
on Sep 1, 2010 at 1:52:44 am
Or try the Gain audio filter and a simple 3-band EQ.
Rich Rubasch
Tilt Media Inc.
Video Production and Post
Owner/President/Editor/Designer/Animator
http://www.tiltmedia.com
Mark Raudonis
on Sep 1, 2010 at 3:15:36 am
You have two choices that come with FCP for free.
Both are audio filters accessible via the "Effects" tab. >>> Go to "Effects". >>> Audio filters. Then, either Apple OR FCP. For Apple you want: "AU dynamics processor". Experiment with the setting. For FCP you want: "Compressor/Limiter".
Keep in mind that if your audio track sounds "distant", just bringing up the volume will NOT change that. It will just be a LOUD bad track. Some EQ can help, but there's no fixing an "off-camera" mic.
Good luck. (Hint: EQ BEFORE compressing. You'll get better results)
Mark
