Text fussy Blury
Tim Glidewell
Text fussy Blury
on Aug 30, 2010 at 5:20:59 am
I'm reordering some pages of text off the internet with the app iShowU HD,
trying to do an on screen tutorial to output to DVD. I'm also mixing it with HDV footage from my canon XH-A1. All the stuff I recorded with iShowU is set up to capture the same size as my sequence setting in FC 1440x1080i60. When I run a small test, 20sec sequence or so from FCP, send that to Compressor, use the DVD: best quality 90 minutes setting in Compressor. Then do my thing in DVDSP well you can't even read the text anymore. I'm going from HD to SD in compressor on purpose. I need the text in this project to crisp, as it should be. Thanks in advance.
Tim
Dave LaRonde
Re: Text fussy Blury
on Aug 30, 2010 at 4:01:35 pm
You probably need to change the vertical position of the web page footage. It may be 1 pixel, a half pixel, but doing so should sharpen things up nicely.
Dave LaRonde
Sr. Promotion Producer
Tim Glidewell
on Aug 30, 2010 at 6:24:48 pm
Thanks for the response. Do you mean just click and drag the web page up or down, how do I know how far to move it?
Dave LaRonde
on Aug 30, 2010 at 6:35:56 pm
You figure out how far to move it through trial and error. Just open up the basic motion tab and move it.
Dave LaRonde
