render issue
Brad Williams
render issue
on Aug 27, 2010 at 3:34:43 pm
I have a weird Final Cut Issue. I have a video file that is captured through a Blackmagic Extreme card into Final Cut. All of a sudden when I add sequences like lower thirds and such, when I go to render, I get an annoying General Error 0 message constantly. My work flow is the same. I am using a Lacie Esata external. I am on a Quad Core Mac pro with 6 GB of ram and running Final Cut 7. Any ideas at all what is up ? I have tried trashing preferences, restarting etc...
John Fishback
Re: render issue
on Aug 27, 2010 at 5:40:42 pm
This might be a case of corrupted media. Checkout Digital Rebellion's FCS Maintenance Pack. There's a Corrupt Clip Finder and they have a demo version. Also, using Render Manager, you might try trashing your renders and re-rendering.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
Jeremy Garchow
Re: render issue
on Aug 27, 2010 at 5:41:36 pm
[Brad Williams] "All of a sudden when I add sequences like lower thirds and such, "
Where are these lower thirds from?
Brad Williams
Re: render issue
on Aug 27, 2010 at 6:03:54 pm
sorry, they are just text lower thirds
Jeremy Garchow
Re: render issue
on Aug 27, 2010 at 6:05:27 pm
[Brad Williams] "sorry, they are just text lower thirds"
Created in FCP?
Brad Williams
Re: render issue
on Aug 27, 2010 at 6:25:25 pm
yes, sorry, created in FCP with Boris
Jeremy Garchow
Re: render issue
on Aug 27, 2010 at 6:31:06 pm
OK, if you remove the title, and put on any filter (say a desaturation filter) and render, do you get the error?
Brad Williams
Re: render issue
on Aug 27, 2010 at 6:37:44 pm
If I remove a section of the text, it still gives me the error
Jeremy Garchow
Re: render issue
on Aug 27, 2010 at 6:38:55 pm
Don't remove a section, you need to remove all of it. DUpe the timeline if oyu have to . I am trying to nail it down to see if it's Boris causing the error or not.
What format, frame rate, timeline settings are you using?
