24 vs 23.98 digitizing HD footage
Johnny Smith
on Aug 27, 2010 at 2:30:37 am
offline sequence in FCP reads 24
Cinema Tools reads 24.
Compressor's settings for DVD are 23.98
My assistant set everything up and he's out of country..
Lab needs to know ASAP frame rate for digitizing HD footage from telecine session. I will be importing these HQ files back into FCP. We shot on 35mm 4perf. I'm guessing 24, any way it could be 23.98?
Johnny Smith
Re: 24 vs 23.98 digitizing HD footage
on Aug 27, 2010 at 2:49:13 am
bump.
this is my last question today i promise.
I really need to know this.
Shane Ross
on Aug 27, 2010 at 2:57:51 am
Bump does nothing. Post still floats to the bottom.
Well, to answer this, we need to know how you are Mastering. Final output to what? And TRUE 24fps? That's what the sequence settings say?
Shane
Michael Gissing
on Aug 27, 2010 at 2:59:23 am
What was the frame rate on the original telecine to do the SD edit?
Johnny Smith
on Aug 27, 2010 at 3:54:05 am
Yes Shane, the sequence setting says '24'.
Good question Michael let me look at the dvcam tapes. Hold on.
Johnny Smith
on Aug 27, 2010 at 4:13:16 am
Talked to Deluxe. 23.98 is correct.
Problem solved.
