Audio clips that played before in timeline won't play now
Ada Ross
on Aug 25, 2010 at 10:49:14 pm
Some clips in my timeline decided to not play after some final editing (audio only). Source clip does play fine. In timeline - can't hear them. Anyone know why? How to remedy?
Michael Gissing
Re: Audio clips that played before in timeline won't play now
on Aug 26, 2010 at 12:56:30 am
Are the clips active and the level not on -inf?
Ada Ross
on Aug 26, 2010 at 2:24:53 am
Yes, no levels. The clips originally came in a different format than the rest, but played for a long period of time with no problem!
Dave LaRonde
on Aug 26, 2010 at 5:28:26 pm
[Ada Ross] "The clips originally came in a different format than the rest, but played for a long period of time with no problem!"
Different formats? Three words: you got lucky. I think your luck has run out.
If it was my project, I immediately would convert those clips to FCP's preferred type of audio: aiff, 48kHz, 12 or 24 bits.
Satisfaction should ensue.
Dave LaRonde
Sr. Promotion Producer
Ada Ross
on Aug 26, 2010 at 5:51:39 pm
Thanks! Yes, different format, but those clips were converted to match the sequence at the beginning. I think you are correct though, just ran out of luck. Solved it by laying over same audio again... The problem only happened in the timeline, and after a month of editing.
Thanks for your response.
Dave LaRonde
on Aug 26, 2010 at 8:42:50 pm
Whoops! I made a mistake on the bit depth: it should be either 16 or 24 bits. I mistakenly wrote 12 bits.
Dave LaRonde
Ada Ross
on Aug 26, 2010 at 2:28:42 am
yes. no levels.
