Proper sequence and export settings for TV commercial
John Galvin
on Aug 24, 2010 at 8:53:16 pm
Final Cut Pro user/beginner - primarily used to producing video for web only... looking for some help with the correct sequence set-up for a TV ad - using non-HD MiniDV video.
Any help with the correct/recommended export process would be greatly appreciated as well.
JG
Shane Ross
Re: Proper sequence and export settings for TV commercial
on Aug 24, 2010 at 10:28:43 pm
With all due respect, there is a LOT that goes into making sure a project can fall within TV specs...more than can be said in a forum post. Especially if your only experience is for the web.
My advice? Find someone in your area that has done this and pay them half a day to make it work, and watch what they do.
But there are separate specs for audio and video...and you need to fulfill both.
Shane
