Best way to remove a hanger
kristin fraser
on Aug 24, 2010 at 7:29:58 pm
I shot an interview and did not notice a coat hanger in the background (half out of a shadow). I need to remove that hanger. I have been playing around in motion and final cut to try to remove the offending hanger with not a whole lot of luck.
Is there a plug in that will help me 'disappear' a steady background image?
Kristin
(and I now always check for hangers)
Mark Suszko
Re: Best way to remove a hanger
on Aug 24, 2010 at 8:03:35 pm
Yes, it is called photoshop. You can use it to paint out every frame of a shot, or you can paint just one frame,using the clone or healing brush for example, and carefully mask the overlay into the cleaned-up background.
Zane Barker
on Aug 24, 2010 at 10:21:04 pm
Just be sure you are billing by the hour because you have to do that to every frame of video.
**Hindsight is always 1080p**
