Make 50fps to 25fps for EDL ?
Ola Haldor Voll
on Aug 23, 2010 at 12:17:37 pm
I'm grading a video for a client. Footage is 720p@50fps. I need to export using EDL to bring it further down the chain, but as far as I know, EDL won't work with 50fps. So I guess I need to make this 25fps..
I tried using Media Manager, but found no solution. I select "recompress" and Prores 422 HQ 25fps, but I'm getting an error message that the setting won't apply to the fps of the clips being recompressed.
I'm a bit stuck here!
Rafael Amador
Re: Make 50fps to 25fps for EDL ?
on Aug 23, 2010 at 12:28:22 pm
Hi Ola,
Just drop the clips in a 25p sequence and export.
One every two frames will be dropped.
If you have a lot of stuff, you can batch export with Mpgstreamclip.
rafael
http://www.nagavideo.com
Ola Haldor Voll
on Aug 23, 2010 at 12:41:39 pm
Hmm well, I tried that. In the grading application it will play all 50fps even though the timeline is 25fps, so the video looks slow motion.
Rafael Amador
on Aug 23, 2010 at 12:59:28 pm
Hi Ola,
You should be getting a 25p file with the same length than the original.
I don't know what you are doing wrong.
rafael
