Problem with Canon 5D mark ii footage at 24 frames in FCP 7
Tatyana Mircheva
on Aug 18, 2010 at 7:59:21 am
Hello,
I recently bought the Canon 5D mark ii camera. The other day I shot a gig which I wanted to edit. The slight (big ) problem is that every time I try to put any king of dissolve between two clips, the timeline would not play back without dropped frames even after rendering. Please help!!! What am I doing wrong?
Tatyana
Michael Gissing
Re: Problem with Canon 5D mark ii footage at 24 frames in FCP 7
on Aug 18, 2010 at 1:28:16 pm
You need to load the files via Log & Transfer. Please search this forum as we answer this query almost daily. Just put in 5D in the search box
Tatyana Mircheva
on Aug 18, 2010 at 1:40:25 pm
Thank you for your response,
I read a lot of forums today but still can not fix the isssue
The problem with log and transfer is that I no longer have the footage on the card but only the .mov files transferred to my mac.(it seems that this plug in requires all original data from the CF card). I tried to turn the files into ProRes 422 for progressive material with compressor, imported them in FCP 7 and the dissolve still didn't work. The dissolves works ok at the beginning and end of a whole clip but not in between two clips. I am sure that the answer is simple and I do apologise if I sound like a beginner.
Thanks again.
Tatyana
Tatyana Mircheva
Robert Due
on Aug 18, 2010 at 2:40:05 pm
Try searching for "Magic Bullet Grinder" it will ignore the file structure that FCP needs when using the EOS plugin during Log and Transfer.
hope that helps.
Robert Due
Editor / Colorist
INDEPENDENT EDIT
