Out of Memory!!
Maurik de Ridder
Out of Memory!!
on Aug 17, 2010 at 9:10:14 am
Hi guys...
Hope you can help me with some weird Out of Memory problems...
I'm editing a internet trailer for Volvo...
Now I got some screencapture, captured with Snapz Pro X, H264 1051x702.
Sequence settings are Prores 1024x576 none
During the project, in some moment I wasn't able to open the clips in the viewer.
Out of Memory Warning. Then I could drag and drop the file in the Timeline, Render there, View in timeline.... Make cuts and drag them in the right place in the edit.. (to annoying and time consuming)
I tried to convert the clips to Prores 1051x702.. and Uncompressed .....Photo JPEG and still Out of Memory warning. or a no codec found warning.
Delete the prefs.... same issues
Copy everything to a new project.... same issues
Copied whole project to another computer same issues...
The strange thing is ... sometimes it opens the clip in the Viewer... but when I try to play the clip it gives the warning..
Other times I can open it and play it in the viewer but then when I make an in or out point it gives the warning...
Other times I can make in and out points but not put it in the Timeline
But most of the times I can't open it in viewer or anything
I never ever had problems editing prores in different sizes (like 1051x702)
Greet Maurik
Shane Ross
Re: Out of Memory!!
on Aug 17, 2010 at 9:36:54 am
That isn't a frame size that FCP is designed to edit. Look at the presets..those are the codecs and frame sizes. 1920x1080...1280x720...not 1051x702. If you use screen capture software, it is best to set the screen dimensions as close to those sizes as possible, then capture at those dimensions exactly. Then FCP won't have any problems.
Maurik de Ridder
Re: Out of Memory!!
on Aug 17, 2010 at 10:00:09 am
Hi Shane...
Thanks for your reply...
I know it's not a standard size... but I never before had any problems editing shots in a timeline with
strange sizes... Just needed to render and Voila...
Now no go..
Freelance Editor
MacPro 2x 2.26 GHz Quad-Core Intel Xeon, 6.0 GB RAM, ATI Radeon HD 4870, Multibridge Pro, Sonnet Fusion DX800Raid 8TB
QT 7.6.0 FCP 6.0.5 Color 1.0.4 Compressor 3.0.5 Episode 5.1.1
Paul Jay
Re: Out of Memory!!
on Dec 13, 2010 at 4:23:11 pm
Asking for troubles.
© 2018 All Rights Reserved
