Frame drops after exporting
Nick Dmytrenko
on Aug 15, 2010 at 5:36:30 pm
Recently, my videos have been dropping a few frames when I export them, making them appear jerky like the video is continuing to load. I'm not sure what the problem is because before my videos would export to Quicktime just fine up until a few months ago. I've played around with the export setting for better quality, but the same thing continues to happen. I'm using Final Cut Express if that makes a difference at all. I'd appreciate that help!
Jerry Hofmann
Re: Frame drops after exporting
on Aug 16, 2010 at 1:14:32 pm
For starters, don't put these self contained files on your startup disk... it's not going to play well from there. Dropping frames usually points at a drive that can't keep up.
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog:
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
© 2018 All Rights Reserved
