XDCAM EX 720p30 footage on a DVCPROHD 720p60 timeline at 23.98fps
Steve Horton
on Aug 14, 2010 at 7:29:40 pm
I'm working on an edit shot primarily on a P2, so my sequence is DVCPROHD 720p60 at 23.98fps. I had my friend shoot the outro on his EX, but he shot it at 29.97. What's the best process to put this footage on a timeline? Should I convert to ProRes at 23.98 in MPEGStreamClip or just bring it straight into FCP as is?
Shane Ross
Re: XDCAM EX 720p30 footage on a DVCPROHD 720p60 timeline at 23.98fps
on Aug 14, 2010 at 8:11:40 pm
Use the XDCAM Transfer tool to convert to QT in it's native format. THen use Compressor to convert and remove the frames. You will have to set the FRAME controls to BEST...and it will take a while..
Shane
Steve Horton
on Aug 14, 2010 at 8:17:38 pm
Thanks....where do I go to adjust the frame controls?
Steve Horton
on Aug 14, 2010 at 9:57:21 pm
NVM....found it in Inspector
thanks again
Shane Ross
on Aug 14, 2010 at 10:34:43 pm
In the INSPECTOR...there's a button for FRAME CONTROLS. Then a Sprocket to turn them ON.
Shane
