Can you access a Soundtrack Pro EQ in FCP?
Eric Susch
on Aug 11, 2010 at 11:58:20 pm
I'm using the Channel EQ in Soundtrack Pro to correct a buzz we have in quite a few interviews. It works great. The parametric EQ's in FCP can't replicate what I'm doing, and the graphic GUI in Soundtrack Pro is great.
The thing is, it's such a pain to roundtrip just to lay in an EQ. Is there any way to use the Soundtrack Pro EQ directly in FCP? Are there any similar audio EQ pluggins that I can purchase that will work in FCP?
____________________________________
Eric Susch
http://www.LetsKnit2gether.com
http://www.EricSusch.com
Follow me on twitter @EricSusch
Paul Figgiani
Re: Can you access a Soundtrack Pro EQ in FCP?
on Aug 12, 2010 at 1:19:46 am
The Soundtrack Pro filters are not accessible in FCP. Audio Unit plugins are, with a caveat: no native UI's. Not very intuitive, especially when using a robust plugin. FCP-->>STP-->>FCP is your best option.
-paul.
