Upgrading to FCC3 - clean install
mortimer heathcliff
on Aug 11, 2010 at 4:35:15 pm
Wiped my drive, installing Snow Leopard now, with FCS3 upgrade after. I hear conflicting opinions on this, but is it advised to install FCS1, then 2, then 3? Seems like i should be able to install only the new FC3 stuff...
thanks for helping out a bonehead!
__________________________
dual 2 GHz PowerPC Mac G5
2GB MB DDR SDRAM
GeForce FX 5200 graphics card
Patrice Freymond
Re: Upgrading to FCC3 - clean install
on Aug 11, 2010 at 5:52:17 pm
install FCS3 upgd, you will be asked for previous version license number. No need to install the previous versions. Depending on your needs you may want to install QT v.7 as well.
hope this helps
Patrice Freymond
Senior editor
FCP Certified Trainer
patrice@monteur.tv
