weird shadow / double image when i export video
Anne-Marie van Rooijen
on Aug 9, 2010 at 10:24:30 pm
Hi all,
I just can't figure out what i'm doing wrong.
When i export footage sometimes it turns out with weird shadow or it seems like e double image. Its only with moving parts like arms waving.
some examples because i cant really explain how it looks:
http://www.flickr.com/photos/52883482@N04/4876650601
http://www.flickr.com/photos/52883482@N04/4876650597
http://www.flickr.com/photos/52883482@N04/4876650589
http://www.flickr.com/photos/52883482@N04/4876650573
It was recorded 1080p
and my latest sequence settings are:
http://www.flickr.com/photos/52883482@N04/4876650559
i already tried 720p and upper or lower in field dominance.
already thnx for the help!!!
Greets,
Anne-Marie
Rafael Amador
Re: weird shadow / double image when i export video
on Aug 10, 2010 at 4:03:48 am
Are you sure that the footage is not 720p50?
rafael
http://www.nagavideo.com
on Aug 10, 2010 at 5:11:01 am
yes im sure. It was recorded on a sony pdw-700 in 1080p
Rafael Amador
on Aug 10, 2010 at 11:02:11 am
There are two pictures.
That picture comes from the original footage (1080i50/720p50) or somehow FC is blending frames.
FC won't do that unless you make some speed changes (with Frame Blending ON).
Have a look to the Browser "Field Dominance" column and see how FC is interpreting the clips.
rafael
Re: weird shadow / double image when i export video (problem solved)
on Aug 10, 2010 at 5:33:40 pm
THATS IT!!!
i did made speed adjustments and blending frames was on.
I turned it off and now it's good.
Thanks!!!
geo godley
on Jul 24, 2011 at 7:28:54 pm
hi, final cut pro is adding double image shaddows on export. tried many settings & your frame blending on/off & nothing works, HELP! PLEASE!
