Exact same images - some are blue/green and some are orange - mystery?
Elijah Lynn
on Aug 9, 2010 at 5:12:52 pm
I have attached a screenshot of my timeline, these images were exported from Powerpoint as an image sequence. I am going through the sequence, laying them down and as soon as I hit slide/image #41 I started getting the "unlimited" render status. This slows down my preview bigtime as I am throwing opacity on the slides and playing back at 2x speed, when the status is the green/acqua color (vs. blue) the audio plays smooth but when it is orange it is virtually inaudible. This is a XDCAM EX 24p 35mbps sequence.
Any ideas? Maybe something simple I am overlooking, this has happened with all the previous timelines too.
964_fcpimagesequencerenderstatusissuewithpowerpointjpgs.png.zip
Rafael Amador
Re: Exact same images - some are blue/green and some are orange - mystery?
on Aug 9, 2010 at 5:25:21 pm
Hi Elijah,
Try rising the "Stills Cache".
BTW, why are you editing in an XDCAM sequence?
Even if you are delivering in that format, you will work much better in a prores sequence.
Cheers,
rafael
http://www.nagavideo.com
Elijah Lynn
on Aug 9, 2010 at 5:51:36 pm
You da man Rafael!!
As far as the XDCAM vs. Prores sequence goes, no reason just inexperience! I thought that it would render faster this way, mainly. I will play around with it.
Cheers,
Elijah
Rafael Amador
on Aug 9, 2010 at 6:02:19 pm
Hi Elijah,
XDCAM is one of the slower rendering options available.
If you are delivering in XDCAM, is better to export to a good Intraframe codec (Prores or Uncompress) and re-encode the final master to XDCAM.
Don't forget to set "Render in High Precision".
Cheers,
rafael
