Transferring Premiere Pro timeline to FCP?
Daniel Grixti
on Aug 8, 2010 at 1:14:57 am
Hi there,
I have a completed 5 min edit on Adobe Premiere Pro CS3 (PC) that I would like to transfer to FCP (Mac) to re-edit.
Is there any way to do this? Any help would be much appreciated.
Dan
Jerry Hofmann
Re: Transferring Premiere Pro timeline to FCP?
on Aug 8, 2010 at 1:22:33 pm
Export an EDL from Premiere and import that to FCP. Recapture in FCP...
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
Dennis Radeke
on Aug 10, 2010 at 11:22:46 am
Assuming you don't want to purchase CS5 which supports FCP XML export, I would try downloading a trial of Premiere Pro CS5, import a COPY of your CS3 project and then see if you can export FCP XML to finish.
Hope this helps.
