Compressor timecode is off
Elijah Lynn
on Aug 3, 2010 at 11:43:52 pm
I am having an issue with Compressor and timecode. I have source material which is EX3/Mpeg 2/1080 24p, I edited my sequence, exported it to self-contained file and it starts at 1:00:00:00 (playback in Quictime Pro 7 verifies this), when I open it in compressor and preview it the timecode starts at 00:59:56:10. I am suspecting this has to do with the framerate.
Any ideas?
I want the timecode to start at 1:00:00:00 because that is the way the sequence is and I have another person who is going to make notes based on that timecode, I want their notes to match my sequence. The export is fine but Compressor doesn't seem to read it right, although Quicktime does.
Elijah
Shane Ross
Re: Compressor timecode is off
on Aug 4, 2010 at 12:01:00 am
Yup...odd bug. Compressor has an issue with XDCAM and DVCPRO HD footage at 23.98 when adding the timecode Reader filter. The only way I have gotten around it is to offset my sequence. Adjust it so that it starts at 01:00:03:14 and see what happens. Or play with the numbers until you get it right.
Shane
Elijah Lynn
on Aug 4, 2010 at 12:07:24 am
So, offest it, re-render, export, compress, and then shift offset back?
Thanks for your advice Shane!
Elijah Lynn
on Aug 4, 2010 at 12:45:28 am
Compressor likes that, thanks for the workflow Shane!
