Final Cut Pro transferring multiple clips
Scott Brown
on Aug 2, 2010 at 2:17:30 pm
Hello,
I logged and transferred a number of clips today from a P2 card using Final Cut 7 and the log & transfer tool. When I had FCP digest the clips it created 3 versions of every clip, each time these clips were identical. This resulted in almost 50gb of unnecessary footage. I've successfully logged and transferred countless times and now the problem persists. Any idea what is wrong? Thanks so much!
Scott
John Fishback
Re: Final Cut Pro transferring multiple clips
on Aug 2, 2010 at 9:14:26 pm
Do you mean that after you selected a clip in L&T and added it to the queue, three QuickTime files appeared in the logging bin? Were they also in the Capture Scratch for that project?
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
