Interlaced to Progressive
Smith Glover
on Jul 30, 2010 at 11:19:49 pm
I am trying to help a client who has the following problem: Their camera guy shot half of their BTS footage at 1080i 59.94 and the other half at 720p 23.98. They want the final export to be 1080 p 23.98- the problem of course being that half the footage is interlaced. The footage was shot on a Panasonic HPX-500 (if that's important at all). Is there a relatively easy fix for this? Is there a program that can convert, at least reasonably well, interlaced to progressive? Any help would be greatly appreciated.
Michael Sacci
Re: Interlaced to Progressive
on Jul 30, 2010 at 11:52:40 pm
Magic Bullet Frames does a good job with this. And you are not just de-interlacing you are changing the frame-rate which is also something that MB Frames does well.
You can test just using Compressor and turning on Frame Control.
Either way to do a good job you it will require a lot of time.
Smith Glover
on Jul 31, 2010 at 12:02:47 am
Thanks Michael- that's very helpful.
