Letterboxing Top and Bottom in DVD Studio Pro
Frank Giardina
on Jul 29, 2010 at 9:48:37 am
Hi...
I'm working with FCP 7, shooting with Canon 7D and a Canon XH A1s. Here's my Sequence Settings.
Time Base: 29.97fps
Frame Rate: 1440 x 1080
Aspect Ratio: 1440 x 1080 (16:9)
Field Dominance: None <--- is that OK?
QuickTime Compressor Settings: 422(LT)
I've tried sending to Compressor and Playing out a QuickTime current settings, then going to Compressor for my mpe2 and audio, and in both cases when I go to DVD Pro and author a DVD I'm getting letterboxing Top and Bottom. I've checked and double checked to make sure I didn't flag anything as letterbox, but I'm still getting it. It's minor when I play the DVD on my computer, and varies a little on a couple different wide screen TVs.
It's making me crazy!
HELP! :)
Frank
Chris Tompkins
Re: Letterboxing Top and Bottom in DVD Studio Pro
on Jul 29, 2010 at 2:49:06 pm
Frank ur shooting and editing in 16 by 9
You want letterbox on a SD DVD.
If Not?
Output Sequence current settings ref file.
Drop into compressor.
Choose a 4X3 option in the settings. This makes a 4X3 mpeg not a widescreen.
Then bring into DVDSP.
Chris Tompkins
Video Atlanta
Frank Giardina
on Jul 29, 2010 at 3:07:28 pm
Hi Chris...
Yes, shooting 16:9 on a Canon XH A1s and Canon 7D ... I'm 1440 x 1080. I'll try the 4:3... last year when I was 720 x 480 anomorphic that worked.
Here's my sequence setting, clip based
Time Base: 29.97fps
Frame Rate: 1440 x 1080 (16:9)
Field Dominance set to none <--- note sure if this is right given I have mixed media
QuickTime Compressor setting: 422 (LT)
Frank
Frank
