Canon 5D
tom fraser
Canon 5D
on Jul 28, 2010 at 10:23:01 pm
I am shooting test with the 5D
Using onboard sound
Input via log and transfer ( Pro Res 422 HQ)
Place on timeline (FCP HD)
Audio is 2 frames out of sync
Steve Eisen
Re: Canon 5D
on Jul 28, 2010 at 11:23:36 pm
Your frame rate is?
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Michael Gissing
Re: Canon 5D
on Jul 28, 2010 at 11:37:09 pm
Your monitoring setup is??
tom fraser
Re: Canon 5D
on Jul 28, 2010 at 11:54:17 pm
24 (23.?)
tom fraser
Re: Canon 5D
on Jul 28, 2010 at 11:55:24 pm
Black Maqgic HD Extreme
Alan Thorburn
Re: Canon 5D
on Jul 29, 2010 at 5:55:12 pm
I have this same camera and FCP setup.
Make sure you are monitoring your sound via the HDMI output and not through the Apple computer's sound card. That would create a 2F offset . . . cause it does on mine.
tom fraser
Re: Canon 5D
on Jul 29, 2010 at 6:00:24 pm
It's all going thru my Balckmagic HD extreme card.
tom fraser
Re: Canon 5D
on Jul 29, 2010 at 6:08:41 pm
the picture and sound track are aligned out of sync by two frames on the timeline
Alan Thorburn
Re: Canon 5D
on Jul 29, 2010 at 10:05:26 pm
I've heard you don't need to use Apple Pro Res HQ, just the regular Apple Pro Res will do. Try doing a test file and see if that helps. Also, try to use your desktop display and run the audio through the Apple sound card and see if that helps.
