How to Log and Transfer (SONY EX1) to External Hard Drive?
Daniel Grixti
on Jul 28, 2010 at 5:00:48 pm
Hi there,
I have been given some EX1 footage to use in an edit and have downloaded the Log And Transfer utility from the Sony website.
I have added the folder containing the footage but when I go to add the clips to the queue it seems as if the destination is the hard drive on my laptop. So what I need to know is how to change the destination to my external hard drive so that when I add the clips to the queue the resulting files will be transfered to my external hard drive, ready to be edited in FCP.
Dan
Andrew Kimery
Re: How to Log and Transfer (SONY EX1) to External Hard Drive?
on Jul 28, 2010 at 6:09:20 pm
Launch the XDCAM Xfer software, go to Preferences, then Import and you set your destination there.
-Andrew
3.2GHz 8-core, FCP 6.0.4, 10.5.5
Blackmagic Multibridge Eclipse (6.8.1)
Doug Beal
on Jul 28, 2010 at 6:11:31 pm
Look in XDCam xfer >preferences>Import and hit the choose button for location
Doug Beal
Editor / Engineer
Rock Creative Images
Nashville TN
Daniel Grixti
on Jul 29, 2010 at 5:27:53 pm
I'm still kind of confused as to how to do this.
I am in Final Cut Pro. I go file > log and transfer > then click the import folder icon.
I can import my EX1 footage but then when I try and add the clips to the queue I am restricted by my hard drive space. This is why I want to send the clips to my external hard drive.
If there is no way to change the destination here then could someone give me a walkthrough on how to use the stand alone application?
Doug Beal
on Jul 29, 2010 at 7:24:14 pm
No you first install the XDCam packages that allow you to read the card, and the XDCam Xfer software then you go file>import>xdcam transfer.
on some stations it opens in the background and you need to go to the dock to bring it foreground.
Inside the XDCam Xfer software under preferences>Import is where you set the destination drive.
The software is here
https://www.servicesplus.sel.sony.com/sony-software-model-PDZKP1.aspx
Doug Beal
Editor / Engineer
Nashville TN
