Noise in the soundtrack in Final Cut Pro
Fernando Lino
on Jul 27, 2010 at 3:10:50 pm
Hey
Every time I import a music to my sequence I hear this repeated noise two times every second and I don't know what's happening. It's almost like the sound of music not rendered but not as loud. I checked the settings and it seems fine, it didn't used to happen.
I would really be appreciated if you could help me out.
Mark Petereit
Re: Noise in the soundtrack in Final Cut Pro
on Jul 27, 2010 at 3:25:59 pm
What is the frame rate of your sequence? And what is the source of the music you're importing?
Fernando Lino
on Jul 27, 2010 at 3:34:31 pm
25 frames the sequence. I'm importing the video from a external disk and the music from my main disk. Do you think that it might be related to that?
Dave LaRonde
on Jul 27, 2010 at 3:26:21 pm
Quit using mp3's or ac3's in FCP. Go with AIFF files, 48k, 16 or 24 bits.
Dave LaRonde
Sr. Promotion Producer
Fernando Lino
on Jul 27, 2010 at 3:40:09 pm
Yeah I'm using mp3s, I can't find the music in question in another format. What do you suggest? To convert the audio files?
Dave LaRonde
on Jul 27, 2010 at 3:46:40 pm
Sundtrack Pro, Quicktime Pro... take your pick.
Dave LaRonde
Fernando Lino
on Jul 27, 2010 at 4:40:48 pm
Thanks! I used the batch export of FCP. The sample rate was of 44.1 khz and i converted it to 48 khz...
Dave LaRonde
on Jul 27, 2010 at 5:34:53 pm
[Fernando Lino] "Thanks! I used the batch export of FCP"
I hope that work. Typically it's a bad plan to use an application that has trouble with a file to do the actual conversion of the file, y'know.....
Dave LaRonde
Mark Petereit
on Jul 27, 2010 at 3:46:42 pm
I know most people dread hearing this, but you really ought to try reading the manual.
Fernando Lino
on Jul 27, 2010 at 4:39:40 pm
Thanks a lot! The sample rate of the song was 44.1 khz and I converterted it to 48 khz.
To be honest I have just read a few pages of the manual. The works keeps pilimp up and i haven't found the time to read it. I was amazed of how concise it is, i'll definitely will try to find the time to read it.
Thanks again.
