Calculating bit rate for encoding HD video for web
Matt Campbell
on Jul 23, 2010 at 5:29:25 pm
If I have a 720p HD video, is there some formula I can use to get that file under 200 megs? I need to create a H.264 file but need to calculate the bit rate for encoding. How do I do so?
For instance, my first try in Compressor was H.264 at 1280x720 using Restrict to 7000 kbits/sec and optimized for Streaming with AAC audio. I got a file that was around 500 megs. I need to be under 200.
Isn't there something like kbits/sec divided by minutes and/or length of video, something like that to get the bit rate at which to encode.
Any encoding guru's out there?
OS 10.6.3, Mac Pro 2 x 2.66 ghz quad-core intel xenon, 16 gb ram, with BM Intensity Pro card
Jeremy Garchow
Re: Calculating bit rate for encoding HD video for web
on Jul 23, 2010 at 5:59:20 pm
I was just doing this very thing.
OK, it's kind of long but here goes. Basically, you have time and file size. In Compressor, file size is listed at kb/sec, so you will have to convert to that.
So you take the time in minutes and seconds, then make it pure seconds. So, if your timeline is 7 minutes and 32 seconds it would be (7*60)+32 = 452 seconds.
So then you take the final file size which is 200MB.
200MB/452seconds = .442 MB/sec
Then you have to convert MB/sec to kbits/sec. For this I use a handy iPhone app called iConvert (free). If you don't have an iDevice, use this:
http://www.matisse.net/bitcalc/
So using the app I find that .442 = 3621 Kb, therefore .442 MB/sec = 3621 kb/sec
No subtract your audio rate, so let's say you are suing 192/kbps audio
3621-192= 3429 kb/sec
Limit your video to that, and you're good. You will need to plugin your own values for time, so your answer will be different/relative to your numbers. 3429 kb/sec is not your answer unless your program is 7m32s.
Make sense?
Jeremy
Matt Campbell
on Jul 23, 2010 at 6:12:09 pm
Ok, let me see if I got this. I'm at 17 min. 49 sec.
(17*60)+49=1069 sec.
200 MB/1069 sec.=.1871 Mb/s
.1871 Mb/s = 1533 Kb/s
1533-128 (audio) = 1405
So 1405 is my bit rate to limit too. Right? Thanks for the help. That calculater link was a bit confusing. I wasn't sure if I should use bits or bytes so I plugged in your ex. to check. Its Megabytes and kilobits. I think.
Jeremy Garchow
on Jul 23, 2010 at 6:16:30 pm
You get a gold star on your math test. Come get a cookie.
Yes, Megabytes, then use the kilobits result.
Dennis Couzin
on Jul 24, 2010 at 4:53:18 am
Mind your B's and b's:
200 MB/1069 sec = 0.1871 MB/s
0.1871 MB/s = 1569 kb/s
1569 kb/s - 128 kb/s = 1441 kb/s
You used an incorrect MB/s to kb/s conversion which multiplied by 8192. One MB is 1024^2 Bytes. One kb is not 1024 bits, but exactly 1000 bits. (Conventions switch as you switch from the computer context to the data transmission context.) Therefore you must multiply MB/s by 8388.6 to find kb/s.
Jeremy Garchow
on Jul 24, 2010 at 7:59:00 am
You can change the notation in the bit calc where 'kilo' = 1000.
Nice catch and sorry about that little omission.
Jeremy
