Keep audio keyframes on frame marker
Jason Brown
on Jul 23, 2010 at 2:59:42 pm
Is there a way to limit the a keyframe to being placed at frames and not in between frames?
I want to use the command shift+K and option+K to move between audio keyframes and use the audio mixer to adjust level...but if the keyframe is between frames and not exactly on the frame marker, it adjusts the level of 2 audio keyframes.
How are others doing this?
© 2018 All Rights Reserved
