dissolve problem
George Seven
dissolve problem
on Jul 23, 2010 at 1:57:55 pm
Every time I add a dissolve on my footage, the dissolve adds a high brightness level. As a result, there is an annoying shift of contrast starting with the transition.
Does someone knows what is going on?
I'm editing a trailer from an avid mxf footage I imported on FCP 7.
Shane Ross
Re: dissolve problem
on Jul 23, 2010 at 5:46:11 pm
Mght be that the codec isn't really supported by FCP. How about transcoding a small bit, a couple shots, to ProRes, and then try the dissolve?
Shane
