XDcam Dual Mono export problem
Dan Hodlick
on Jul 21, 2010 at 8:22:29 pm
Hi All -
I am trying to output a clip form FCP using the XDCam plugin. I know that the media all has to be dual-mono, and everything is up to spec. In my bin, under 'audio', all the clips show up as 2 mono.
When I click on a clip and select export/xdcam, a box comes up that says "the clip has stereo audio channels. It is only possible to export clips with mono audio channels".
I've tried exporting the clip through quicktime conversion to discrete audio, and a few other tricks but nothing has worked. I'm at a complete loss....
Any help?
Thanks in advance!
Wayne Carey
Re: XDcam Dual Mono export problem
on Jul 21, 2010 at 9:40:54 pm
You sequence has to be set to dual mono audio in its settings.
_______________________________
Wayne Carey
Schazam Productions
http://web.mac.com/schazamproductions
schazamproductions@mac.com
