exporting DVCProHD 1080p from timeline
Dovydas Vilkelis
on Jul 21, 2010 at 11:41:56 am
Hi guys,
I have a strange problem. When I try to export DVCProHD 1080p clip from my timeline, which is 1440x1080, I get a clip with resolution 1920x1080. How can I fix it?
__
DTG Video
Video production
http://www.dtg.lt
Chris Tompkins
Re: exporting DVCProHD 1080p from timeline
on Jul 21, 2010 at 1:19:08 pm
That's what it supposed to do. HD, When full raster is 1920 X 1280
Chris Tompkins
Video Atlanta
Jeremy Garchow
on Jul 21, 2010 at 3:22:13 pm
[Chris Tompkins] "1920 X 1280"
1920x1080.
That's Quicktime doing the real time anamorphic stretching. Your clip is still 1440x1080.
Jeremy
Chris Tompkins
on Jul 21, 2010 at 3:46:23 pm
That's what I meant.
Thanks.
Chris Tompkins
Video Atlanta
Dovydas Vilkelis
on Jul 21, 2010 at 6:14:09 pm
Okay, so there is another problem. I export some clips for use in Nuke,
and it is stretched too much. No matter what pixel aspect ratio I make in Nuke project, square or 1.333. Is it possible to avoid quick time stretching to 1920x1080? Or maybe there is another solution?
__
DTG Video
Video production
http://www.dtg.lt
Jeremy Garchow
Re: xporting DVCProHD 1080p from timeline
on Jul 21, 2010 at 7:12:45 pm
Are you changing anything when you export?
Should be File > Export > QuickTime Movie
Make sure 'make self contained' box
Is checked.
Dovydas Vilkelis
on Jul 21, 2010 at 7:19:32 pm
I do exactly what you wrote. When I watch video with QT player, it's ok.
__
DTG Video
Video production
http://www.dtg.lt
Jeremy Garchow
on Jul 21, 2010 at 7:26:33 pm
Nuke must not understand the aspect ratio of DVCPro Hd.
Dovydas Vilkelis
on Jul 22, 2010 at 12:12:50 pm
Nuke understands it, when I import video just after transferring from camera.
__
DTG Video
Video production
http://www.dtg.lt
Jeremy Garchow
on Jul 22, 2010 at 12:23:14 pm
So, after you log and transfer, if you take one of those quicktimes to Nuke, it's ok. But if you export from FCP, it's no good.
Can you take a screenshot of your sequence settings?
Dovydas Vilkelis
on Jul 22, 2010 at 5:31:12 pm
I don't think it's sequence issue, because FCP makes settings, when I insert some footage on timeline. I just don't want QT stretch, because after that some problems occurs in Nuke. It thinks footage is 1920x1080, but with 1.33 pixel apsect ratio.
__
DTG Video
Video production
http://www.dtg.lt
Joel Arvidsson
on Aug 1, 2010 at 7:59:44 am
Why not use the reformat node?
joelarvidsson@gmail.com
