Sequence to Clips
Martyn Morris
Sequence to Clips
on Jul 21, 2010 at 9:47:02 am
Hi there,
is there a way of splitting up a sequence into individual clips back in the browser?.
Thanks Martyn
Chris Guevarra
Re: Sequence to Clips
on Jul 21, 2010 at 6:11:47 pm
This is a lengthy solution but you could try nesting the sequence and then export it into it's own QT movie file then import it back into your project as you would any media and then break it down into subclips.
1) Nest the sequence
2) export it into a QT file
3) import it as a master clip
4) break it down into subclips
Chris Guevarra
seekingasianfemale.com
massmovementtv.blogspot.com
cowcowcowcowcow
Martyn Morris
on Jul 22, 2010 at 8:02:31 am
Thanks for the reply Chris.
That does sound like a lengthy solution but one that would work.
In the end I copied the clip from one sequence and insert paste (shift - V) in to an other.
Martyn.
