Quick Question: Does FCP 6 work well with Tiger (OS X 10.4.9)?
Chris Guevarra
on Jul 20, 2010 at 5:45:19 am
Hey Cows,
Quick question:
We're looking to upgrade from FCP 5.1.4 to FCP 6 on Mac OS X 10.4.9. Has anyone done this and how did the transition go? Are there any known problems in upgrading to FCP 6 while using Tiger OS.
Thanks everyone!
Chris Guevarra
massmovementtv.blogspot.com
cowcowcowcowcow
Michael Gissing
Re: Quick Question: Does FCP 6 work well with Tiger (OS X 10.4.9)?
on Jul 20, 2010 at 7:37:06 am
I ended up with the last Tiger and FCP 6.0.6 which worked fine on my old G5.
I have since upgraded everything including hardware to SL, FCS3 which is even better
cowcowcow
Jesus Ali
on Jul 20, 2010 at 11:19:20 am
I believe FCP 6 was originally released on Mac OS 10.4 so that should be no problem at all.
Are you certain you're not thinking about FCP 7 (the latest. FCStudio 2009, i.e. 3)?
I believe that FCP 7 is NOT compatible with 10.4, and requires 10.5.6 or thereabouts.
If you have an Intel machine why not jump right to FCP 7 and Snow Leopard? The multi-processor benefits will be HUGE! :)
Good luck.
Chris Guevarra
on Jul 20, 2010 at 5:49:12 pm
Thank you both so much for your help.
Anyone else have any positive (or negative) experiences upgrading FCP 5 to FCP 6 on Mac OS X 10.4.9?
Chris Guevarra
