Calibrated {Q} IMX Decode message
Atticus Brady
on Jul 18, 2010 at 6:33:42 pm
Hi everyone!
Recently, when opening a Final Cut sequence, a message appeared within the thumbnail in the timeline that didn't exist before. The message says "Calibrated {Q} IMX decode." The message also pops up when trimming a clip. Does anyone know what this means and how to make it disappear?
Atticus
Jeremy Garchow
Re: Calibrated {Q} IMX Decode message
on Jul 18, 2010 at 6:52:12 pm
Sounds like you had a calibrated demo software installed:
http://www.calibratedsoftware.com/QIMX.asp
User guide will tell you how to uninstall:
http://www.calibratedsoftware.com/downloads/CalibratedQ-IMX-UserGuide.pdf
Jeremy
Atticus Brady
on Jul 18, 2010 at 8:06:36 pm
Thanks Jeremy. I followed the uninstall instructions, dumping all the calibrated settings and folders from the hard drive, re-started, and while the calibrated message has disappeared from a couple of the thumbnails and it no longer appears during a trim, it remains visible in most of the thumbnails (it's a 35-min sequence with lots of edits). Any other suggestions?
Atticus
Greg Booth
on Jul 18, 2010 at 8:45:34 pm
FCP caches thumbnails so you would need to turn off then turn back on thumbnails or clear your cache to force FCP to re-make your thumbnails.
Cheers,
Greg
Calibrated Software
Atticus Brady
on Jul 18, 2010 at 10:21:52 pm
Thank you for your help gentlemen. I wound up trashing the Thumbnails Cache Folder and that did the trick! Thanks again.
Atticus
