Video not exporting completely
Chris Woods
on Jul 15, 2010 at 3:52:38 am
Having trouble exporting an HD clip to NTSC settings and every time I export it the file is not complete. The video clip is about 93 min. and only 74 min. of it export. Everything is render and no in and out points are set and when I export under Current Settings it works fine, but when I select Custom and set the codec to Apple ProRes or 10bit uncompressed it cuts off at 74 min. Not sure if it's the codec that's doing it or that I have the Pixel Aspect Ratio set from HD to NTSC. I never seen anything like this in Final Cut before when exporting clips. Hope someone can help and thank you for your time.
© 2018 All Rights Reserved
