ProRes Proxy to ???????
Don Walker
on Jul 11, 2010 at 11:32:41 pm
I have a 94:38:00 Indie movie shot on DVCPro HD 720p and AVCHD (HMC-150). The DVCPro HD footage is not converted on the timeline, but most of the AVCHD footage is ProRes Proxy. I have read that ProRes LT is a good format for AVCHD footage.... Does the Herd agree with this or should I transfer to a higher bit rate ProRes for the final project. The ultimate goal of this movie is theater distribution, but that remains to be seen. Second question: given my source footage, would laying the final timeline off to DVCPro HD be an adequate format or should I spend big bucks on D-5 HD or HDCAM SR.
Thanks in advance
Don Walker
John 3:16
Jerry Hofmann
Re: ProRes Proxy to ???????
on Jul 12, 2010 at 12:25:19 am
The higher the bit rate you use theory would say you'd improve the end result.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
