time & date code transfer
Steve Tamou
on Jul 8, 2010 at 12:35:11 am
After transferring the video file from my sony avchd camcorder to FCP, I don't know if the time and date code gets transferred with the file. And, if I delete the file from the camcorder, the time & date infromation will be lost. Am I supposed to manually put that infromation in at log and transfer? Thank you in advance.
Jerry Hofmann
Re: time & date code transfer
on Jul 8, 2010 at 1:30:28 am
FCP doesn't read that metadata, so you've guessed right, need to do this during Log and Transfer manually, or after the fact in a description column in the Browser one clip at a time...
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
jon smitherton
on Jul 8, 2010 at 1:51:34 am
Yes there is a need for this - hopefully this feature will be in the next version - you can read up on a discussion here:
There is a tool for this; however, it costs -
Colin Browell
on Aug 7, 2010 at 9:59:13 am
If you have access to a Windows PC, "DVDate" and "DVMP Pro" may help too.
© 2018 All Rights Reserved
