Converting HD footage to SD
JIm Culhane
on Jul 7, 2010 at 7:43:00 pm
I have been trying to get the best results converting HD footage to SD.
The footage was shot with the EX-1, 1080i60. I have edited the footage in HD and copied the HD timeline into a SD timeline, exported that timeline into compressor, compressed at the best quality, and the footage does not clear. The footage looks washed out, not crisp. I'm not sure if I need to change some settings.
Any help would be great.
Thanks so much in advance.
Michael Sacci
Re: Converting HD footage to SD
on Jul 7, 2010 at 8:21:02 pm
[JIm Culhane] "I'm not sure if I need to change some settings. "
Maybe if you posted your settings we could give you feed back.
Jeremy Garchow
on Jul 7, 2010 at 8:33:01 pm
[JIm Culhane] "The footage was shot with the EX-1, 1080i60. I have edited the footage in HD and copied the HD timeline into a SD timeline, exported that timeline into compressor,"
Wrong order. Export an HD movie, bring that to COmpressor, then make the SD movie out of Compressor. Ir if you are going to DVD, then just make the SD MPEG2 from the HD movie.
Jeremy
