Can capture HD but not SD
Jonathan Andrews
on Jun 30, 2010 at 4:44:50 pm
Please Help, I am unable to capture in SD for some strange reason. I am using Final Cut Pro 6.06
For the past year I have been able to capture with the following easy setup settings: Format = NTSC, Use = DV-NTSC Anamorphic, Rate = 29.97 fps. With that setup I have been able to capture from my Sony HDR-FX1.
However, as of right when I attempt to capture from tape, I get the preview disabled window. I can control the camera utilizing log and capture and I can hear the audio, but I can not capture video.
On the flip side, I can capture HD video. I use the following easy setup settings: Format = HD, Use = HDV - 1080i60, Rate = 29.97fps.
I have tried capturing from multiple SD and HD tapes so I know the tape I am using is not the problem.
Any direction you can provide would be greatly appreciated.
- Jonathan
Dave LaRonde
Re: Can capture HD but not SD
on Jun 30, 2010 at 7:34:26 pm
Have you gone into the camera's menu to change the video output from HD to SD?
Dave LaRonde
Sr. Promotion Producer
