Audio Mixing a Sequence
James Coppens
on Jun 29, 2010 at 10:36:47 pm
I have a sequence that is a collection of clips. I am doing a voice over but I want to lower the sound of the sequence during my voice over. I've been doing this by manually lowering the decibel level of each clip in my sequence, is there a way to lower the level of a highlighted area without affecting the master level so the voice over decibel level isn't affected?
Many Thanks
http://www.jimmycoppens.com
Dan Charrington
Re: Audio Mixing a Sequence
on Jun 29, 2010 at 10:49:03 pm
Select all the clips you want to adjusts and choose Modify>>Levels (or Command+Option+L)
You can adjust the Gain in the slider that appears. The two choices (Relative/Absolute) mean the following:
Relative: adjusts all clips relative to what they are currently set at. ie - a clip at 10db will go to 4db if you enter "-6"
Absolute: sets all clips to whatever level you enter. ie - a clip at 10db will go to -6db if you enter "-6"
Hope that helps.
Dan Charrington
Supervisor, Non-Linear Technologies
MIJO
635 Queen St E. Toronto, ON
416-964-7539
MacPro 8-core Xeon 2.8GHz, 10gb Ram, AJA Kona 3 SD/HD
Illya Laney
on Jun 29, 2010 at 10:51:25 pm
Highlight all the clips you want to adjust then hit control + or - to raise and lower dB. It helps to have keyframe overlays turned on so you can keep track of the relative volume levels.
Motion Design, Color, Editing
SWGC Incorporated
James Coppens
on Jun 29, 2010 at 11:33:53 pm
You are the man! Can I facebook friend you? I've been struggling with that one for a week or so!!
Illya Laney
on Jun 30, 2010 at 5:05:44 am
Haha. No problem.
SWGC Incorporated
