Can I shorten a master clip to make hard drive space?
Paul Boone
on Jun 24, 2010 at 11:49:38 pm
I usually like to go through clips when capturing and not import excess, but when I'm in a hurry I just import all clips and use what I need.
I know about subclips but that doesn't free up hard drive space.
Can I just remove excess from a master clips so it doesn't take up unnecessary space?
Paul
Brian Miller
Re: Can I shorten a master clip to make hard drive space?
on Jun 25, 2010 at 12:28:25 am
better yet you should media manage your sequence. that will make a new sequence with everything offline, and a list of just the clips actually used in the cut...
Paul Boone
on Jun 25, 2010 at 2:56:36 am
[Brian Miller] "better yet you should media manage your sequence. that will make a new sequence with everything offline, and a list of just the clips actually used in the cut..."
I was told that media manager can be risky to use. That it was fine for making backup copies but I'm kind of scared to delete the original file if I just have the media managed copy. I guess if I try the new copy and some files work, it should all be fine?
Thomas Morter-Laing
on Jun 25, 2010 at 9:28:08 am
Can someone say how to do this please?
:D
Tom Morter-Laing
Certified Apple Product Proffessional, 2010
Production Assistant, Grace Productions
Degree; TV Production
John Knapich
on Jun 25, 2010 at 1:38:06 pm
Sub clip the portions of the master clips you want to keep.
Media Manage the subclips, copying them to new files.
Delete the old master clips once you are sure you have all your new clips.
FCP 6.06, OS 10.5.8 2x3GHZ Quad-Core Intel Xeon, Kona LHe, Dulce Duo-eSATA 8 Drive, 4TB Raid.
John Knapich
Creative Director/Partner
Assembypix.tv
