Final Cut Transition problem
Robert Greim
on Jun 24, 2010 at 6:23:02 pm
Can someone help me with a transition problem? When I try to add
a CROSS DISSOLVE to a cut nothing happens. When I retry the same step
the CROSS DISSOLVE is applied to every cut on my time line.
I have been working with Final Cut for months and have not had this problem before. What am I doing wrong?
Tom Wolsky
Re: Final Cut Transition problem
on Jun 24, 2010 at 7:49:16 pm
Are there enough handles available on the adjacent clips to create the overlap for the transition?
All the best,
Tom
Class on Demand DVDs "Complete Training for FCP7," "Basic Training for FCS" and "Final Cut Express Made Easy"
Author: "Final Cut Pro 5 Editing Essentials" and "Final Cut Express 4 Editing Workshop"
Robert Greim
on Jun 24, 2010 at 9:05:04 pm
Yes there are enough handles. This is happening on all clips.
I opened another finished project and it is happening on those
clips that worked fine prior.
Bob
Tom Wolsky
on Jun 24, 2010 at 11:20:37 pm
What version of the software is this> How exactly are you adding the transitions?
All the best,
Tom
Robert Greim
on Jun 25, 2010 at 2:23:01 am
I am using Final Cut pro 7..
I move play head on to the cut.
I use the pull down effects menu and choose Cross Dissolve.
It has worked for me many times before.
Bob
Tom Wolsky
on Jun 25, 2010 at 9:21:54 am
Try selecting the edit by pressing the V key and then press Cmd-T. Does it work?
Have you tried trashing your preferences?
All the best,
Tom
Robert Greim
on Jun 25, 2010 at 3:20:08 pm
Yes, the V cmd-T worked. It gave me my cross dissolve on the clip I had chosen and only that clip.
How do I select another effect with this key board shortcut other than
the cross dissolve?
The pull down menu is now working as well.
Thanks a lot
Bob
