Pyro AV Link Audio Latency
Jenny Mettee
on Jun 22, 2010 at 1:28:46 am
I have a VCR which I have hooked into the Pyro with RCA cables and then the Pyro going into my Mac Pro with FireWire. I turned off "abort capture for dropped frames" and my capture settings are non-controllable device, and DV NTSC 48Khz Advanced. I now can record without it stopping but the audio latency is horrible. Any suggestions?
Also, when I play back what was captured, it will play the audio, with the latency, but if I stop the clip, I cannot hear any audio unless I play the clip from the beginning.
I have 16 gigs of ram and the ATI Radeon HD 3870 video card and FCP 7.0.2
Rafael Amador
Re: Pyro AV Link Audio Latency
on Jun 22, 2010 at 9:56:22 am
Hi Jenny,
What kind of hard drive are you using?
rafael
http://www.nagavideo.com
Jenny Mettee
on Jun 22, 2010 at 2:02:47 pm
All internal drives. The fcp file is on a separate drive than what I am capturing on. FCP itself is running on a separate drive too. So total 3 different drives.
Jenny Mettee
on Jun 22, 2010 at 7:50:35 pm
Or are you asking about brands of hardrives? Then all Seagate Barracuda 1.5tb 7200's, except the Western Digital Hard drive which is my OS X and FCP application drive that came with the machine.
Rafael Amador
on Jun 23, 2010 at 2:29:17 am
No Jenny, I was wondering if you were using any USB or FAT-32 formated HD.
rafael
Jenny Mettee
on Jun 23, 2010 at 2:31:03 am
Nope all OS X journaled drives.
Rafael Amador
on Jun 23, 2010 at 5:08:01 am
With internal HDs and your RAM this shouldn't be happening.
No clue Jenny, but whenever I have this kind of issues (glitches, slow performance..) I start by running Diskwarrior.
90% of the FC problems comes from a poor System maintenance.
rafael
