simultaneous 4-channel DV audio capture: change over time and reason
Anthony Guest-Scott
on Jun 21, 2010 at 5:40:39 pm
To All,
I work at an archive, and we have a large collection (800 MiniDV tapes) that we are transferring to digital files. I've just run across our first 4-channel, 12-bit 32 kHz tape, and suspect there could be more. We're interested in creating a digital file from this tape that is identical to the original tape, and so would appreciate the ability to capture all 4 audio channels simultaneously (and have them really exist as 4 separate tracks within the QuickTime file).
Our setup:
MacPro with two 3 GHz processors and 4 GB RAM
OS X 10.6.3
Final Cut Pro 5.1.4
Sony HVR-M15AU DVCAM/HDV deck
I've read in many posts, both here and elsewhere, about the difficulties with capturing all 4 channels of DV audio simultaneously. And I've read the following passage in the FCP 5 user manual:
"About Capturing Multiple Audio Channels From DV Devices
DV video devices can record up to four tracks of audio, depending on the sample rate and bit depth chosen on the camcorder. However, Final Cut Pro can only capture two audio channels via the FireWire port of a device at a time."
My questions are these:
1. A colleague of mine tells me that he used to capture all 4-channels of DV recordings he made simultaneously, with all 4 appearing as individual tracks within the FCP timeline. He says this might have been 8 or 9 years ago now. Has this, then, changed over time?
2. If so, why?
3. Are there Mac-based alternatives to try and do this you can suggest?
Anthony
Mark Petereit
Re: simultaneous 4-channel DV audio capture: change over time and reason
on Jun 21, 2010 at 6:52:22 pm
The two-channel audio limit is a limitation of *Firewire*. As long as you're capturing using a hardware device that supports 4 audio channels, you should be fine.
I capture HD-SDI video through an older BlackMagic HD Extreme board using Final Cut Pro's Log & Capture and it captures 4 channels with no problems.
Anthony Guest-Scott
on Jun 21, 2010 at 7:07:54 pm
Thanks, Mark.
I have read this before, but I must confess that I don't quite understand why it would be a limitation of Firewire. I understood Firewire to be simply a vehicle for transporting data as 1's and 0's from one component to another. Is there some way this data is output from devices or packaged that would cause it to be limited to transporting a certain number of audio tracks?
Anthony
Anthony
Mark Petereit
on Jun 21, 2010 at 7:29:12 pm
Dunno. I learned everything I know about it reading the snippet from the user manual you included in your original post. :-D
Just curious, what hardware device are you using to capture?
Anthony Guest-Scott
on Jun 21, 2010 at 9:33:33 pm
We are capturing MiniDV tapes from the Sony DVCAM/HDV deck through Firewire directly into the CPU of the MacPro, so there is no other hardware component in the chain.
Anthony
Mark Petereit
on Jun 21, 2010 at 11:17:45 pm
Sounds like you'll definitely want to start looking for a good deal on a BlackMagic or Kona card. Or here's a great deal on an Aja IoHD!
Rafael Amador
on Jun 22, 2010 at 9:42:21 am
[Anthony Guest-Scott] "I have read this before, but I must confess that I don't quite understand why it would be a limitation of Firewire. I understood Firewire to be simply a vehicle for transporting data as 1's and 0's from one component to another"
Yes, but you must tell the FW interface which data to transport.
This is what the Capture Presets are for.
Had you tried to duplicate and edit your DV Capture Preset?
Rafael
http://www.nagavideo.com
Anthony Guest-Scott
on Jun 22, 2010 at 6:15:21 pm
Thanks, Rafael.
Yes. The audio options offered in the Capture Preset Editor allow for these options for Input (from a DV Audio device):
-First 2 channels
-Second 2 channels
-Mix 4 channels
And these for Format:
-48.000 kHz 16-bit 2 chan
-44.100 kHz 16-bit 2 chan
-32.000 kHz 16-bit 2-chan
So this interface allows one, leaving aside the question of resolution for the moment, to capture all 4 channels of audio in two separate passes, or mixed as stereo pair - but not 4 separate audio tracks in a single pass, which is what we're after.
Anthony
Rafael Amador
on Jun 23, 2010 at 3:02:59 am
Hi Anthony,
I've been Googeling about this issue but I haven't found any solution to get that done in FC.
HOWEVER, I think that may be possible just using QT.
Switch your device on, and in QT open a "New Movie Recording".
Before, have a look to "Recording" in the QT Preferences.
QT should be able to records whatever comes through your FW.
I think it may works, but I can not test it. No 4 channels MiniDV around.
rafael
Anthony Guest-Scott
on Jun 25, 2010 at 2:02:56 pm
I appreciate you looking into this issue, Rafael, and my apologies for taking so long to respond.
You know, I have tried your suggestion of capturing directly in QuickTime Pro (7.6.6, in this case). Here is what happens:
Opening the file in QT and looking at the audio settings for the sound track under Properties shows 4 channels, with the first channel assigned as Mono and the rest described as "unused." This is accurate when compared with the source tape. And, when dragged to a Final Cut Pro timeline, I do see 4 tracks of audio appear there.
I should not that when I play back this file (in QT or FCP), the sound plays back as dual mono instead of true mono (on the left channel) as was present on the source tape. This seems to be an issue with sound output on the computer workstation however - routing that audio through both sides of my headphones - because when I look at channels 2, 3, and 4 in the FCP Viewer, there is no waveform.
But here's the catch...when I look at item properties for this file in FCP, it tells me that all channels were recorded as 16-bit 32 kHz audio instead of 12-bit. Furthermore, a MediaInfo report shows the following (copied below). I am not exactly sure how to interpret the audio information in this analysis. It looks like it is showing 3 audio tracks, and I am confused about how to interpret the channel information contained for each track and bit rate - some say 12, others say 16.
General
Complete name : /AHEYM_video_testing/4_channel_12bit_32k/atm_09010d04_mdv352_qt.mov
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 40.0 MiB
Duration : 10s 877ms
Overall bit rate : 30.8 Mbps
Encoded date : UTC 2010-06-25 13:40:31
Tagged date : UTC 2010-06-25 13:40:34
Writing library : Apple QuickTime 7.6.6
com.apple.quicktime.make : Apple
com.apple.quicktime.model : MacPro1,1
com.apple.quicktime.software : Mac OS X 10.6.3 (10D573)
com.apple.quicktime.creationdate : 2010-06-25T09:38:50-0400
com.apple.quicktime.player.movie : (Binary)
Video
Format : Digital Video
Codec ID : dvc
Bit rate mode : Constant
Bit rate : 24.4 Mbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Original display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 fps
Standard : NTSC
Resolution : 8 bits
Colorimetry : 4:1:1
Scan type : Interlaced
Bits/(Pixel*Frame) : 2.357
Stream size : 37.3 MiB (93%)
Encoding settings : ae mode=manual / wb mode=automatic / white balance= / fcm=manual focus
Encoded date : UTC 2010-06-25 13:38:59
Audio #1
Format : lpcm
Codec ID : lpcm
Bit rate : 2 048 Kbps
Channel(s) : 3 channels
Sampling rate : 1 Hz
Resolution : 16 bits
Stream size : 2.66 MiB (7%)
Audio #2
Format : PCM
Muxing mode : Digital Video
Muxing mode, more info : Muxed in Video #1
Bit rate : 768 Kbps
Channel(s) : 2 channels
Sampling rate : 32.0 KHz
Resolution : 12 bits
Video delay : 666ms
Stream size : 0.00 Byte (0%)
Audio #3
Format : PCM
Bit rate : 768 Kbps
Video delay : 666ms
Menu
Bit rate mode : CBR
Anthony
Rafael Amador
on Jun 25, 2010 at 3:45:31 pm
[Anthony Guest-Scott] " should not that when I play back this file (in QT or FCP), the sound plays back as dual mono instead of true mono (on the left channel) as was present on the source tape."
In a digital file, the mono channels are not assigned to the left or the right as they were recorded on camera. I mean, if you play a QT file with Mono channels, you will get the same output through both loudspeakers. You may "pan" the channels when you mix to stereo, or you may route those channels when you are printing to tape.
rafael
Mark Petereit
on Jun 25, 2010 at 4:25:31 pm
If you double-click on your first audio channel in the Final Cut Pro timeline and look at the viewer, you'll see a pan setting which is most likely set in the center. This is why you hear your mono channel in both sides of your headphones.
Anthony Guest-Scott
on Jun 25, 2010 at 8:31:59 pm
I see. So, it sounds like, from what Rafael suggests, that digital audio generally, when represented as Mono, does not assign it to a particular left or right stereo (or surround, for that matter) output.
Thanks, Mark, for suggesting that solution in FCP. Another way I've found is by using the Assignment drop-down list in QuickTime's audio settings for the file (in the file's sound track under Properties). For my example, I can just set Channel 1 to "Left" instead of "Mono."
Anthony
