Sharp QT text becomes blurry when rendered
Jeff Gerst
on Jun 17, 2010 at 8:20:23 pm
I have a QT mov with text in it & the text looks super clean in the Canvas window, but when I render it, the text gets blurry.
I even tried changing my QT video settings in my sequence to uncompressed - still super sharp text in unrendered preview, blurry on render in the canvas window.
Any ideas?
Thx
Shane Ross
Re: Sharp QT text becomes blurry when rendered
on Jun 17, 2010 at 10:29:21 pm
Set your canvas to 100%. How does it look now?
Shane
Jeff Gerst
on Jun 17, 2010 at 10:36:13 pm
Thx Shane - that's the problem - looks perfect at 100% in canvas, unrendered. I render it & loses resolution.
B.J. Ahlen
on Jun 18, 2010 at 2:02:05 am
If your sequence is NTSC (or PAL) DV, search this forum to read the posts from the previous 53,812 times this question has been answered since the sad beginning of DV.
Eat lots of garlic, and to be safe put a stake through it.
Jeff Gerst
on Jun 18, 2010 at 2:05:03 pm
Sequence is HD - Images attached
Before Render
After Render
Bret Williams
on Jun 19, 2010 at 6:37:05 am
Before render, the text file was a 16:9 image being shown full rez (was it a screen shot or something?). After render, it has been physically rendered into a 960x720 file, and is being horizontally stretched and displayed as 16:9. It has lost resolution after render. You're working in an anamorphic HD format.
Bret Williams
Web Design . Motion Graphics . Video Editing
http://www.bretwilliams.com
Bret Williams
on Jun 19, 2010 at 6:38:34 am
Also, notice how the image has only lost rez horizontally, not vertically, further demonstrating the issue.
Jeff Gerst
on Jun 19, 2010 at 8:49:38 am
Cool, Brett.
But how do I fix that?
Yes, both images were screen grabs.
Bret Williams
on Jun 19, 2010 at 3:03:39 pm
Work in a true HD sequence. 1280x720z. Why are you working in animation codec? I would work in a 720p pro res sequence.
Jeff Gerst
on Jun 19, 2010 at 3:18:02 pm
Animation looked cleaner. I tried 1280x720 but text wasn't clear either. Will check that again.
I don't know if it helps, but the text is from a Camtasia screen recording.
Thx.
Nick Narodny
on Aug 19, 2010 at 2:17:05 am
Hi Jeff,
I am having the same problem with my text in FCP. Did you figure out this issue? I hate editing in Camtasia so I export all of my grabs in ProRez HQ but they still aren't coming out right after a final render in FCP.
Please help!
